Using Digital Pots
muso52
Hi People,
I am lookiing at the use of using a digital pot as an analogue input (0 - 5v) to a pic.
As there is no apreciable load on the device I think all will be well but If anyone has knowledge of these devices and have some relevent comments I would welcome them.
Willy
hi Willy,
As the rate of change of voltage input to the PIC's ADC will be slow, a pot of around 10K will be OK.
Some PIC d/s state 5K or 10K as being a maximum 'source' impedance if you you require a fast sampling rate.
E
EDIT:
What value of Dpot do you want to use in this application.?
Good Afternoon Eric,
The manual pot input to the PIC (at the moment) is a 10k across 5v which was recomended. So I guess a 10k digital would be Ok.
Secondly it will be 'clocked' very slowly so do not forsee any problems.
For info the dig pot is replacing a man pot used as a CC controller input to a midi pic.
Willy
You know that most digital pots can not have a signal beyond the supply voltage. (0-5V) man pots don't seen to care.
Hi Ron,
I appreciate that but the max input voltage to the pic is ....5V the same as source.
Also I read somewhere that the 'pot' bottom end has to share ground with Vcc.
Not sure if that applies to all digi pots.
Willy
Good Morning guys,
I hope this dosn't appear lazy but can anyone recomend a simple digital pot with the following?
Non-Volatile
10K
Non SPI (or SPI disable)
256 step if possible.
simple up/dn interface
Pdip
Thanks,
Willy
Digikey.com. or most parts venders, search for digital pot. You can mark no to spi. Yes to dip etc.
Up/down pins & Non-V. = Maxm & Nuvoton
DS1809 is not what you want but.....
also look at MAX5128
  • DS1809.pdf
Hi Ron,
Urr.....Duh Didn't think of that. Getting old(er).
