ZenZ94
I am using EdSim51 to display LCD with Assembly language, but I could only display the 1st line LCD bar. Is there any existing command to call the 2nd line LCD bar?
here's my using code:
; put data in RAM
MOV 30H, #'A'
MOV 31H, #'B'
MOV 32H, #'C'
MOV 33H, #'D'
MOV 34H, #'E'
MOV 35H, #'F'
MOV 36H, #'G'
MOV 37H, #'H'
MOV 38H, #'I'
MOV 39H, #'J'
MOV 3AH, #'K'
MOV 3BH, #'L'
MOV 3CH, #'M'
MOV 3DH, #'N'
MOV 3EH, #'O'
MOV 3FH, #'P'
MOV 40, #'Q'
MOV 41H, #0 ; end of data marker
; initialise the display
; see instruction set for details
CLR P1.3 ; clear RS - indicates that instructions are being sent to the module
; function set
CLR P1.7 ; |
CLR P1.6 ; |
SETB P1.5 ; |
CLR P1.4 ; | high nibble set
SETB P1.2 ; |
CLR P1.2 ; | negative edge on E
CALL delay ; wait for BF to clear
; function set sent for first time - tells module to go into 4-bit mode
; Why is function set high nibble sent twice? See 4-bit operation on pages 39 and 42 of HD44780.pdf.
SETB P1.2 ; |
; same function set high nibble sent a second time
SETB P1.7 ; low nibble set (only P1.7 needed to be changed)
SETB P1.2 ; |
; function set low nibble sent
; entry mode set
; set to increment with no shift
CLR P1.7 ; |
CLR P1.6 ; |
CLR P1.5 ; |
SETB P1.2 ; |
SETB P1.6 ; |
SETB P1.5 ; |low nibble set
SETB P1.2 ; |
; display on/off control
; the display is turned on, the cursor is turned on and blinking is turned on
CLR P1.7 ; |
CLR P1.6 ; |
CLR P1.5 ; |
SETB P1.2 ; |
SETB P1.7 ; |
SETB P1.6 ; |
SETB P1.5 ; |
SETB P1.4 ; | low nibble set
SETB P1.2 ; |
; send data
SETB P1.3 ; clear RS - indicates that data is being sent to module
MOV R1, #30H ; data to be sent to LCD is stored in 8051 RAM, starting at location 30H
loop:
MOV A, @R1 ; move data pointed to by R1 to A
JZ finish ; if A is 0, then end of data has been reached - jump out of loop
CALL sendCharacter ; send data in A to LCD module
INC R1 ; point to next piece of data
JMP loop ; repeat
finish:
JMP $
sendCharacter:
MOV C, ACC.7 ; |
MOV P1.7, C ; |
MOV C, ACC.6 ; |
MOV P1.6, C ; |
MOV C, ACC.5 ; |
MOV P1.5, C ; |
MOV C, ACC.4 ; |
MOV P1.4, C ; | high nibble set
SETB P1.2 ; |
MOV C, ACC.3 ; |
MOV P1.7, C ; |
MOV C, ACC.2 ; |
MOV P1.6, C ; |
MOV C, ACC.1 ; |
MOV P1.5, C ; |
MOV C, ACC.0 ; |
MOV P1.4, C ; | low nibble set
SETB P1.2 ; |
delay:
MOV R0, #50
DJNZ R0, $
RET
