Cantafford
Hello,
I'm trying to interface an 16x2 LCD with an ATMega32 microcontroller. I have watched and understood a simple tutorial and followed the steps to do it. However when I run the code the LCD turns on and displays the cursor but I cannot display any characters on it.
I'm interfacing the LCD in the 8 bit mode and I have connected it like this(it's a simulation I'm not wiring an actual LCD):
Here is the code I wrote:
Please help me identify the issue here if possible. Thanks for reading!
![2cwk8ep.png](https://i68.tinypic.com/2cwk8ep.png)
* LCD.c
* Created: 1/9/2017 4:09:35 PM
* Author: Paul
#include <avr/io.h>
#include <util/delay.h>
#define F_CPU 1000000L
#define EIGHTbits PORTB
#define DataDir_EIGHTbits DDRB
#define LCDcontrol PORTD
#define DataDir_LCDcontrol DDRD
#define Enable 5 // enable
#define ReadWrite 7
#define RegisterSelect 2
void Check_IF_MrLCD_isBusy(void);
void Peek_A_Boo(void); // in prototypes you have to always put something in the paranthesis :D
void Send_A_Command(unsigned char command);
void Send_A_Character(unsigned char character);
int main(void)
DataDir_LCDcontrol |= 1<<Enable | 1<<ReadWrite | 1<<RegisterSelect; // Enable, R/W, RS made as outputs
_delay_ms(15); // wait 15ms after the microcontroller is on so the LCD can turn on
Send_A_Command(0x01); // Clear Screen
_delay_ms(2);
Send_A_Command(0x38); // configure the LCD in the 8bit mote // check the LCD's datasheet for commands
_delay_us(50);
Send_A_Command(0b00001110); // second 1: display on(1) or off(0), third 1:cursor on or off, last one: cursor blinking(1) or not(0)
_delay_us(50);
Send_A_Character(0x4E); // Display character
Send_A_Character(0x65); // Display character
Send_A_Character(0x77); // Display character
Send_A_Character(0x62); // Display character
// Cursor increments automatically
while(1)
DataDir_EIGHTbits = 0; // must be in the input mode
LCDcontrol |= 1<<ReadWrite; // make sure it's in READ mode
LCDcontrol &= ~1<<RegisterSelect; // also make sure it's in the COMMAND mode
while(EIGHTbits >= 0x80) // D7 PortB Pin7 (if it's one means it's busy). If it's 0 means it's not busy. Calling the Peek_A_Boo fills EIGHTbits with values
Peek_A_Boo();
DataDir_EIGHTbits = 0xFF; // 0xFF means output for each of the pins(bring it back to output when it's done cuz it's the only instance when we read)
void Peek_A_Boo()
LCDcontrol |= 1<<Enable;
asm volatile ("nop"); // volatile instruction means the compiler won't optimize it
asm volatile ("nop"); // used for delay after we "turn the Enable on"(TURN enable to 1)
LCDcontrol &= ~1<<Enable; // then we turn it off
Check_IF_MrLCD_isBusy();
EIGHTbits = command;
LCDcontrol &= ~(1<<ReadWrite | 1<<RegisterSelect); // !!!!!! we make sure it's in the WRITE mode
Peek_A_Boo();
EIGHTbits = 0; // erase the information once it's transmitted
EIGHTbits = character;
LCDcontrol &= ~(1<<ReadWrite); // !!!!!! we make sure it's in the READ mode
LCDcontrol |= 1<<RegisterSelect; // now he's ready to recieve a character
Peek_A_Boo();
EIGHTbits = 0;
