adavison17
G'day all,
I'm putting together a distribution box that takes 3 x 20A power curcuits in (each on a different phase), and switches these to separate 10A loads (two per phase). The loads are 2400W heating elements in a small brewery.
I'm not familiar with SSR's, and have the following question:
If I am attaching the SSR's to a heatsink, do I need to keep the SSRs on each phase electrically isolated, or can all 6 SSRs sit on a single large heatsink?
I thought I had the answer when I saw a text that indicated that the heatsinks need to be connected to a protective earth, and figured that it would be sufficient to connect them all to the common earth of the 3 phase supply.
However on measuring the potential between neutral and the SSR back I noticed it was 3-5V, leading me to believe that connecting all the SSRs electrically is probably not wise.
Furthermore, the whole device is in an aluminum rack case, so I'll have to build some insulating stand-offs for the heatsinks...
Any advice would be very much appreciated.
Regards,
Andy
Regards,
Andy
