electroliite
Firstly I have to admit this is a homework question, but I am really confused about it.
Problem : "5. You have found that all components have 0V across it and the power supply has the correct voltage. What are you looking for as a problem?"
Now there are three possible answers:
A. Bad power supply
B. Open component
C. Shorted component
However, if the the power supply has the correct voltage, and there are zero volts across each component then there isn't an open component. One component must have the source voltage across it.
If there was a short then all the components would have zero volts, but also the power supply would have a lower voltage?
Please help
A. Bad power supply
B. Open component
Please help
