venkatkumar.muneeswaran
I have igbt and diode data sheet used for inverter and rectifier circuit design.
i need simulate inverter in ltspice using the voltage controlled switch component.
How obtain to these values from the igbt/diode data sheet
datasheet is attached here
could anyone please help it?
Name | Description | Units |
Ron | Resistance in forward conduction | W |
Roff | Resistance when off | W |
Vfwd | Forward threshold voltage to enter conduction | V |
Vrev | Reverse breakdown voltage | V |
Rrev | Breakdown impedance | W |
Ilimit | Forward current limit | A |
Revilimit | Reverse current limit | A |
Epsilon | Width of quadratic region | V |
Revepsilon | Width of reverse quad. region | V |
Is | saturation current | A |
Rs | Ohmic resistance | W |
N | Emission coefficient | - |
Tt | Transit-time | sec |
Cjo | Zero-bias junction cap. | F |
Vj | Junction potential | V |
M | Grading coefficient | - |
Eg | Activation energy | eV |
Xti | Sat.-current temp. exp | - |
Kf | Flicker noise coeff. | - |
Af | Flicker noise exponent | 1 |
Fc | Coeff. for forward-bias depletion capacitance formula | - |
BV | Reverse breakdown voltage | V |
Ibv | Current at breakdown voltage | A |
Tnom | Parameter measurement temp. | ºC |
Isr | Recombination current parameter | A |
Nr | Isr emission coeff. | - |
Ikf | High-injection knee current | A |
Tikf | Linear Ikf temp coeff. | /ºC |
Trs1 | linear Rs temp coeff. | /ºC |
Trs2 | Quadratic Rs temp coeff. | /ºC/ºC |
