Nick Mulder
Hello,
I have a 2200w grinder motor (240v, 50Hz) here which I would like to be able to run at different speeds - i.e. from zero up to its full supply rpm...
If this were a DC motor I'd simply tap some of the voltage off elsewhere or get more sophisticated with PWM etc... But with AC I dont know what is going on... does the motor run off the frequency of the supply and lowering the voltage would simply reduce its torque ? or ?
Basically its a one off application with time constraints, what simple method could I use ? I'm hoping a simple AC 'dimmer' circuit will do it
...there are two wires coming out of it now that I have removed the trigger
any help appreciated,
Nick
Nick
