Variable microsecond delay in C
JeanTech
Hi there
I'm currently busy with a project that generates PPM frames to control an RC plane. I'm using mikroC to compile
my project and I'm using a PIC16F627A.
I need a way to generate precise microsecond delays at 4Mhz clock. It should also be adjustable (when I
call the procedure it must accept the custom delay time as an argument of the procedure).
My idea is the same as the built-in delay API's, but it must accept variables and not constants (so that I can
adjust delay times in runtime).
How can I generate the microseconds delay routine in C?
Thanks in advance
JeanTech
