Take a look at this schematic of a pc power supply I want to convert into a variable supply for testing heater elements.
https://www.eejournal.org/wp-content/uploads/2010/10/SMPS-IC-2003.gif
I have pulled r60 and r62 and replaced them with a 200k pot, it works well the 12v output now goes from 2.5v to 14v and then the overvolt shtdown comes in as expected.
So I've broken the tracks on the board to the 2003 driver chip, on pins 3,4 and 6 thinking that would remove feedback and stop overvolt shutdown and I'd be able to go to 16v or over, but it doesnt the chip still shuts down, if anything at a bit lower voltage, why?
The only thing I thought of next was to ground those pins I disconnected to see if its just picking up noise on those pins causing the shutdown.
Yes I am aware of the high voltage dangers around switchers.
