Hi Guys,
I need a variable resistor between the range 10k-100k. What potentiometer value do I look for?
in terms of wiring, Do I connect the middle pin and one other together hence making it a 2 pin device?
Thx
I've work this out, Thanks
If a value between 10 and 100K is needed use a combination of a fixed 10K resistor and a pot of 100K.
Using just a 100K pot you'll be able to crank it down to a value of zero Ω, thus making the timer circuit inop.
Boncuk
Also you might consider using a 10 turn trim pot rather then a single turn standard pot, it makes adjustments much easier if it's a set and forget application.
Lefty
