A varicap is made to have a wide range of capacitance change when its reverse voltage is changed. But an ordinary diode or transistor junction has a narrow range of capacitance change when its reverse voltage is changed.
It is VARICAP, not vericap.
Any signal diode is a varicap but its range of capacitance change is very low. An extra capacitor is not needed because when a diode is reverse-biased then it does not conduct and has a small capacitance that changes a little when the reverse bias voltage is changed.
You might need a coupling capacitor to block the bias voltage.
Look at the datasheet for a 1n4148 small signal diode. When its reverse bias voltage is 2V then its capacitance is typically 0.84pF as shown on a graph in its datasheet. With a reverse bias voltage of 15V then its capacitance is a little less at 0.81pF.
The capacitance of a 2N4401 transistor changes from 9pF at 0.1V to 2.3pF at 50V.
Your problem is that you are looking at very old circuits on a website in a 3rd-world country so the parts are not made anymore.
You should look for a modern circuit on a Western website.
I know of no substitute for a varicap. Adding an external capacitor to a standard diode will not increase the range of the capacitance variation.
Have you tried to find a replacement equivalent?
