I'm busy with a project which I need to power on 5 relays at the same time.
The relay's are 5V each and consume 150mA when powered.
So in total they should draw 750mA
I bought a transformer but now am not sure its 'powerful' enough?
Its a 230V/12V - 3VA 50Hz transformer.
Does that mean it can put out 3V at 1A (ie 5V at 3/5A?)
Would that mean is too small to drive all my relays on at the same time? I would need a 750mA * 5V (3.75VA) Transformer?
I would have to put the output of the transformer through a rectifier and then a 5V regulator - would that make things even worse?
What would happen if the transformer is too small to power all the relay - would they just not all power on, or would the relay eventually burn out?
