Hellen Grig
I have to design a sinusiodal voltage amplifier with a voltage gain of 5400 and a specified bandwitdh . Wich soluttion is better :with transistors or with OA?
The only conditions I have are:What is the bandwidth?
What is the load? (current, voltage output)
I already thought to a Common Emitter Amplifier , 2 stages, maybe , but the problem is that I don’t Really know What TBJ to use . What characteristics I m looking for ?Use a microphone preamp (transistors or opamp) with an audio power amp IC driving a transformer.
But a suitable audio transformer is probably not made anymore so you will need to design a transistor amplifier to produce the 27V (77V p-p) output.
You will need a power supply with about 82VDC output.
BJT , sorry . TBJ is in my language .What is a "TBJ"?
The output power of 27V into 16 ohms is 46W. A common emitter class-A stage will get extremely hot all the time even when there is no input signal. You need a complementary class-AB pair of emitter followers plus at least two transistor common emitter amplifiers.
27 V RMS .Is Vout 27 volts peak, peak-to-peak, or RMS?
Does the load have to be connected to ground? If not, then two ampl running BTL will cut the power supply voltage requirement in half.
ak
Then you're looking at power supplies of +/-39 Vdc for the output waveform, plus some headroom for the output transistors, so somewhere around +/-45 Vdc at a minimum of 2.4 Apeak.27 V RMS . The load must be Connected to Ground , I think .
I speak in words, not letters. A Bipolar Junction Transistor is clear in any language. An Opamp is also very clear but OA could be anything.
The output current of almost all opamps is way too low for a 16 ohms load.
My bad,sorry. I will follow your advice .
Our teacher said us that is easier to design it with OpAmps . I used 2 stages , first Av=90 and second stage has Av=60. It works ok , I have 27V from 5mV ,but I ignored load resistance . When I place it, the output voltage is limited. How can I solve this ?
I was hoping the OP would find Apex on her own.if you do a search for "power op amp", in addition to the LM3886, you will likely get a lot of hits for devices made by Apex.
