Hi all,
I've got quick question.
A voltage comparator compares an input voltage with a ref voltage and if higher than the ref voltage, the outup will go high, right?
Can I use the same principle but instead of the the output going HIGH I would want it to go LOW. So the output should go from HIGH to LOW when the input voltage exceeds the ref voltage.
I'm using the LM393 IC
