Hi can someone out there put me straight please.
I want to fit a longer lead to a domestic tumble dryer, the mains voltage is 230 volt.
The connection rating of the dryer is 2600 watts, so I would say I’m looking at 11.304 amps current draw.
The new lead will be 2.5 metres long twin and earth pvc covered cable with a 3 pin plug on the end which will simply be plugged into a conventional wall socket outlet. ie it won’t be buried in the wall, running with other cables or covered by loft insulation .
Obviously, there is a maximum permissible for voltage drop as there is for any cable.
Can someone show me how to work this out, showing if the new cable would be acceptable for this application, Iv'e no doubt it will be acceptable but I would like to do the sums
My thanks to anyone who doesn't mind doing a little maths![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Clive
Clive
