Do you mean the loss in voltage of an open circuit capacitor due to leakage resistance of the capacitor?One of the tests that i have been requested to do by my manager in order to validate a capacitor is to measure the voltage loss across the capacitor,
That's something you don't have to measure, is it?reactive Power dissipated in a capacitor
Because I have no idea what he means.the voltage loss across the capacitor,
In which case the question should have been "what is the ESR of the capacitor."I mean by voltage loss, the one caused by ESR of the capacitor.
I've always assumed that the ESR was an actual resistance and is the leakage (DC) current through a capacitor. Is this wrong?Since ESR (Equivalent Series Resistance) is fundamentally a resistance, the voltage drop (not loss) of a device is a function of the current through the device. So you need to specify that current. Since DC does not flow through a capacitor, you may also need to specify the frequency of the AC current.
Edit, google tells me I'm wrong!!! Oh well.
The reason you never see it mentioned is because meters that can measure it don't call it EPR (equivalent parallel resistance), they call it Rp. They also call ESR by the name Rs. Even the low cost currently available LCR meters like the DE-5000 can measure both Rs and Rp.I would imagine so, what you were thinking would be a parallel resistance, not a series one.
You never see EPR mentioned![]()
Do you mean that measurements are affected by frequencies? in fact i was wondering about that many times when using my LCR meter to measure ESR, each time i change the frequency i get a different value, so which one is the real ESR !!?LCR meters have modes to measure these things at various frequencies.
Thank you,ESR Frequency dependency -
What are impedance/ ESR frequency characteristics in capacitors? | Murata Manufacturing Articles
Find Murata's technical articles.article.murata.com
Regards, Dana.
Thank you,
What's your comment on the following please,
it's saying ESR is not a frequency dependent !
ESR does vary with frequency, but sometimes it doesn't vary much, and sometimes it varies a lot.Do you mean that measurements are affected by frequencies? in fact i was wondering about that many times when using my LCR meter to measure ESR, each time i change the frequency i get a different value, so which one is the real ESR !!?
