Hi, firstly sorry if this is a really simple question, but I have no idea about electrics or electronics... Im a mechanical engineer by trade (sorry! )
Anyway, I have a voltage signal which varies depending on speed output of a motor, and need a way to alter this voltage. Its 0-12v and low current (a couple of amps max; I can confirm this if its important, but as its a signal, I dont think its very high)
I need something I can put inline with this voltage signal so the output reads zero until the input reaches a pre-defined value, then it can read as normal from there... ie the output reads 0v when the input reads 0 to say 3v, then it jumps to the input value (ie 3v-12v input = 3v-12v output).
Im not sure if this is a good description, but I hope someone can understand it and point me in the direction of a part, or circuit of parts that would do the trick...
I dont know the exact voltage I need it to switch at currently, but I can find this out, or better yet, if someone could tell me what I need to calculate in order to "size" the components, I could do it myself...
Thanks in advance, and sorry if this is a really stupid question...
b
b
