geoffers0_0
Hi
I'm planning to use a Recom R-785.0-0.5 https://www.electro-tech-online.com/custompdfs/2009/04/R-78xx-10.pdf
switched regulator to convert a nominal 7.4V from a LiPo battery to a 5V output, to power the Rx & servos in a RC model glider
I have been told I need the following capacitors on the input & output sides
.. simply solder a 100uF on the input and 10uF output
Are these caps. necessary for an application such as this?
Do the values sound about right? - how does one calculate the values required? is there a rule of thumb / design criteria for this
Thanks, Geoff
Thanks, Geoff
