Voltage regulator Comparison
spike47
Hi
I am trying to find a equivelant to this regulator MCP1700-2102E/TO from Microchip technology , I need 2.1 Volts output in a 3-Pin TO-92 package.
There seems to be plenty of 1.8 v and 3.3v around ! .
attached data sheet
spike
  • MCP1700-2102E_TO Microchip Technology _ Mouser for uploading.pdf
Hi
Thanks for your reply , could not find any there , I have found a data sheet for one but it is a old data sheet by TelCom semiconducter inc , who are now Micochip , back were I started ! .
cheers
spike
The closest I can find is the Holtek TO92 2.1v, most of the 2.1v are custom devices.
E
  • 71xx_1v170.pdf
Does it have to be TO-92? If your more flexible on that requirement you will have better luck finding a similar part that is adjustable. For example:
https://www.mouser.com/ds/2/268/22070a-53890.pdf
The MCP1824/MCP1824S is a 300 mA Low Dropout
(LDO) linear regulator that provides high current and
low output voltages. The MCP1824 comes in a fixed or
adjustable output voltage version
, with an output
voltage range of 0.8V to 5.0V. The 300 mA output
current capability, combined with the low output voltage
capability, make the MCP1824 a good choice for new
sub-1.8V output voltage LDO applications that have
high current demands. The MCP1824S is a 3-pin fixed
voltage version.
Also take a look at this selection Matrix:
https://www.mouser.com/Microchip/Se...tors/_/N-5cgacZscv7?P=1z0zl2wZ1z0si72&FS=True
I'm afraid if you stick with your TO-92 requirement, your gonna limit your choices. Party on :)
E
Hi
Thanks for reply , yes they will do tks , will now see where I can get them form .
ps: like your avatar , my old school badge in north yorkshire , but in green
cheers
spike
, with an output
voltage version.
Hi
Thanks for your reply , yes I do need them to be in a 3-Pin TO-92 package , but ericgibbs as found some for me in a TO-92 package , just hope that they are available .
cheers
spike
When I've had similar issues where I have to replace a custom-voltage three terminal regulator......................I build a small board with the regulator IC which can provide me with the proper voltage and its associated components, and have a three pin header coming out of it with the same pin configuration as the older regulator.
If done with SMT components, you can make it fit.
