I need to parallel 2 7808 to double the Amp required (each circuit takes 1 Amp ) 2 Amps are needed . Can I just parallel them or do I need a resistor between output pins for maybe a slight voltage difference ? I can also use a To3 transistor cage but space is a must ..
Thanks for taking the time .. Bobby
