Wake from sleep using INT0
tubos
The following piece of code should make the pic sleep
and keep on sleep until INT0 edge is detected.
The problem is it immediately wakes up again
from itself after going to sleep.
PIC18F26K22 & MPLAB v8.84 & C18 v3.41
while(1)
		for(ucb=0;ucb<100;ucb++)  // Just some led displaying stuff
			uca +=1; uca &=0x01F;
			BrtData[0]=uca;
			Delay10KTCYx(10 );
		INTCONbits.GIE=0;		// Should be off just wake from sleep
		LATB=0x00;				// Turn off Leds
		LATA|=0x0F;				// common Anodes off
		Delay10KTCYx(250 );		// Just to check
		TRISB = 0x01;			// Bit 0 input for INT0
		INTCONbits.INT0IF = 0;  // Must be off prior to enable INT0
		INTCON2bits.INTEDG0=1;  // Enable Rising edge
		INTCONbits.INT0IE=1;	// Enable INT0 interrupt
		Sleep();
		Nop();
		TRISB=0;				// Back to normal
		INTCONbits.INT0IE=0;	// Disable INT0 interrupt
		INTCONbits.GIE=1;		// Back on
One possibility: you have a mismatch condition on RB0. Read RB0 before clearing the INT0F flag (INTCONbits.INT0IF = 0).
