samcheetah said:get the august 2004 issue of EPE. there is an article in that issue that may give you alot of help
Nigel Goodwin said:samcheetah said:get the august 2004 issue of EPE. there is an article in that issue that may give you alot of help
Yes, and you can download the software from their website.
samcheetah said:and here is the link for the software
Nigel Goodwin said:samcheetah said:and here is the link for the software
You're getting very good at this Sam! :lol:
Gadget said:This is going to be a 3feet tall robot so space is not an issue. The reason I am using the 18 is because I have never used it before and want to try it.
From what I herd it is alot better then the 16xxx series.
:lol: Gadget: 18Fs are cool but keep in mind that programs written for 16F will need to be modified to run on 18F also hardware has more feature and therefore it is more compicated. But once you will start with 18F, it's not a big deal...Nigel Goodwin said:Gadget said:This is going to be a 3feet tall robot so space is not an issue. The reason I am using the 18 is because I have never used it before and want to try it.
'Better' is a very relative term!, the 18F series are more complicated to use as they have a larger instruction set, although if you are already experienced with the 16F series it's not a large change - but you need to be VERY aware of the differences between the two series, there are a number of differences that aren't obvious at forst glance.
The 16F series is already the equivilent of using a sledgehammer to crack a nut for this job, moving to the 18F series is using a steamroller to do the same job :lol:
In robotics speed is rarely a problem, a PIC will spend almost all it's time doing nothing except wasting time - changing from 16F to 18F will probably increase the 'wasted time' from something like 99.5% to 99.7%.
Yes, it's a good one...MrMikey83 said:Jay posted the website I used for my keyboard.
