Want to share this code [avr based frequency meter with full code and design files]
magvitron
Active Member
its a frequency meter. designed using atmega 8 (avr studio and avr gcc)
proteus file :
View attachment freq counter.zipi
hex file:
View attachment freq_lcd.zip
#define F_CPU 8000000UL
#include <avr/interrupt.h>
#define USART_BAUDRATE 9600
#define BAUD_PRESCALE (((F_CPU / (USART_BAUDRATE * 16UL))) - 1)
#include <stdlib.h>
#include<avr/io.h>
#include<util/delay.h>
short val,val1,i;
unsigned int presc;
char a[10];
char ff[3] = {'v','a','l'};
void usart_init();
void usart_putch(unsigned char send);
unsigned int usart_getch();
int main()
    DDRD = 0x02;
	//counter1 initialization
    TIMSK |= 1<<TICIE1;
	//TCCR1B |=
	TCCR1B |=(1<<ICES1)|(1 << CS12) | (1 << CS11) | (1 << CS10);
	//counter 0 initialization
    TIMSK |= (1<<TOIE0);
	TCCR0 = (1<<CS02) | (1<<CS00);
	_delay_ms(50);		// delay of 50 mili seconds
	usart_init();		// initialization of USART
	sei();
	while(1)
/*	switch (presc)
     case 1024:
     case 256:
	    TCCR0 = (1<<CS02);
	case 64:
		TCCR0 = (1<<CS01) | (1<<CS00);
	case 8:
		TCCR0 = (1<<CS01) ;
	case 1:
		TCCR0 = (1<<CS00);
	default :
	return 0;
void usart_init()
	UCSRB |= (1 << RXEN) | (1 << TXEN);
					// Turn on the transmission and reception circuitry
	UCSRC |=  (1 << UCSZ0) | (1 << UCSZ1);
					// Use 8-bit character sizes
	UBRRL = BAUD_PRESCALE; // Load lower 8-bits of the baud rate value..
							// into the low byte of the UBRR register
	UBRRH = (BAUD_PRESCALE >> 8); // Load upper 8-bits of the baud rate value..
									// into the high byte of the UBRR register
	while ((UCSRA & (1 << UDRE)) == 0); // Do nothing until UDR is ready..
							// for more data to be written to it
	UDR = send; // Send the byte
	while ((UCSRA & (1 << RXC)) == 0);
				// Do nothing until data have been received and is ready to be read from UDR
	return(UDR); // return the byte
ISR(TIMER0_OVF_vect)
        val =TCNT1;
		TCNT1=0x00;
		TCNT0=0X00;
		TIFR =0x00;
	    val =(val/13.107)*100;
		itoa(val,a,10);
		for(i=0;i<=3;i++)
        usart_putch(ff[i]);
		for(i=0;i<=10;i++)
        usart_putch(a[i]);
		_delay_ms(100);
might be useful
When looking at the Microcontroller category, you can find at the sub category "Code Repository".
Here You can Place Your Code and design Files to share with other users.
