Warm SMD Voltage Regulator
superflux
My 78M05b SMD voltage regulator is getting warm (140° F) driving a 7 segment LED running around 126ma.
Is this a cause for concern? Is there a better VR that I should be looking at that might be a similar size?
Thanks!
SF
EDIT: FWIW, the voltage coming into the VR is ~15 volts.
your regulator just gets to about 60deg/C.
It has to dissipate 1.26W and I consider gaining that temperature being normal.
You might reduce the input voltage to 9V at which it has to dissipate ~500mW.
Boncuk
Yes, it has a maximum die operating temperature of 150°C (300°F) so you've got nothing to worry about, see the datasheet.
