danielsmusic
this is a silly one realy, but if i put 2 mains wires into a bowl of water and put my finger in the bowl im not going to get electricuted am i? unless im grounded of course.
danielsmusic said:this is a silly one realy, but if i put 2 mains wires into a bowl of water and put my finger in the bowl im not going to get electricuted am i? unless im grounded of course.
Sounds like a stupid way how to die. :?danielsmusic said:this is a silly one realy, but if i put 2 mains wires into a bowl of water and put my finger in the bowl im not going to get electricuted am i? unless im grounded of course.
zachtheterrible said:How could you get severely shocked if you're not grounded? IF any electricity goes through you, it would only go through your finger and nothing else.
I doubt your brain will function after you find out the answer for yourself.if i put 2 mains wires into a bowl of water and put my finger in the bowl im not going to get electricuted am i? unless im grounded of course.
Are you sure? I did something very similar(posted about it somewhere here already too) at 5 I used a fork and shorted active and neutral if I recall correctly. I most certainly got stuck my mother kicked my arm off the socket. I've also been thrown by grabbing a soldering iron by the wrong endinstruite said:(as you might be knowing AC current thows you out while DC make you stick)
See the following websitekazakhan said:Are you sure? I did something very similar(posted about it somewhere here already too) at 5 I used a fork and shorted active and neutral if I recall correctly. I most certainly got stuck my mother kicked my arm off the socket. I've also been thrown by grabbing a soldering iron by the wrong endinstruite said:(as you might be knowing AC current thows you out while DC make you stick)![]()
Someone Electro said:Thats also why toching an output if an TV flyback transformer is not dengerus.But since its up to 200W it will burn you.
zachtheterrible said:Think about it though, the electricity does not have anywhere to go through you (assuming you're not grounded). The electricity is going to go straight from one wire to the other, you are not in the conduction path. It's like a bird sitting on top of an HV line. Electricity takes the path of least resistance which in this case is through the water.
mstechca said:Doesen't our brain have something inside it that conducts electricity?
Are you calling me a liar? Whilst it may generally be the case it's obvious from my circumstances it is not the rule. Also the answer you've pointed to is quite poor which follows :-instruite said:See the following website
https://www.school-for-champions.com/science/feedback.cfm?topic=AC
check the reply for the question titled "AC versus DC when holding the wire"
I wouldn't test that idea if I were you :shock:zachtheterrible said:but the electricity wouldn't get to the brain unless your head was grounded.
Neither would I. that's why I leave it a theory :lol:I wouldn't test that idea if I were you
Isn't the human body (and other animals) something like 65-70% water?.
