Love reading the stuff on this site. More interesting ideas to explore on my own time! ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Anyway, anyone work with water storage systems used to store energy?
The reason I ask is that I have a stream less than 150 ft from my house and about 40 ft lower in elevation. Plus I have hill behind my house with about 60 ft higher elevation at the top.
The hose run is around 400 ft top to bottom.
I already have brass/stainless steel positive displacement gear pumps that also make good water motors and start at less than 5 psi head pressure.
And I have a lot of 1.5 inch ID irrigation line too so flow rates can be reasonable.
How much power can I produce from the elevation drop of 100 ft?
Say I want to produce 1 kw returnable energy at 70% system return efficiency. How many gallons of water have to flow down the hill to get that 1 kw of usable power?
Any thoughts?
This is just a feasablility question. I Dont plan to build it unless its going to give a resonable energy storage without having to use a million gallons of water to make it work!
Any thoughts?
