Awesome! Thanks for the quick answer.It appears to be a "4mm HXT"; a rather odd type. You are better off cutting that off and replacing with XT60 connectors. They are a common standard and quite cheap.
Or you can get plug-in adapters from Hobbyking:
HXT 4mm Male/Female to XT60 Female Battery Adapter (2pcs)
One end has a 4mm HXT male/female connector and the other has an XT60 female connector. Specs: Battery Connectors: 4mm HXT male/female, XT60 female Wire Covering: Silicone Wire Colors: Red/Black Wire Diameter: 14AWG Length: 30mm Quantity: 2pcshobbyking.com
