Hi fellas. What do you think about the potential of this amplifier project: https://www.eleccircuit.com/power-amplifier-ocl-100w-with-mj802-mj4502/
It is the first on the page. My goal is 50 to 100w rms per speaker. I have an enclosure I built for two 6.5" peerless hds drivers and I will be using one small PA compression horn tweeter. I am undecided if I am going to use a 3 of these, one per driver or one of these just for the PA horn and a TDA7294 btl 2channel amp for the two 6.5s.
My 6.5s are 8 ohm and the horn is 6. I have thought of the compromise of using a single amp such as this for the 6.5" drivers in parallel and get 50w per speaker out of it.
The link I posted is a horrible discription because they have bad English and do not specify what load the 100w is obtained from.
Also I forgot to mention I have a +/-43V 300VA toroidal 60hz transformer.
And last here is a pic of my enclosure which lacks the horn tweeter cutout rightnow which will be mounted on the upper part of the baffle and between the 6.5"s.
![vx9y.jpg vx9y.jpg](https://www.electro-tech-online.com/attachments/vx9y-jpg.85216/)
The enclosure is meant to be oriented with drivers facing sideways not up as dipicted by the way. There is a port on the side of the box. The pcb I etched and masked myself sitting on top of the box was built up as a 3 channel tda7293 ic amp but it failed. For some reason all my 12 board attempts have blew up when powered. So I ordered a board which is on its way.
My latest power supply board pcb layout:
![tgm8.jpg tgm8.jpg](https://www.electro-tech-online.com/attachments/tgm8-jpg.85217/)
It uses 12 50v 4700uF caps, 6 per rail. Is that overkill or no? The board also has the area for the bridge rectifier.
