Morning Eric,hi C.
Clip:
Unsigned Integers of 8 bits. A uint8 data type contains all whole numbers from 0 to 255. As with all unsigned numbers, the values must be non-negative. Uint8's are mostly used in graphics (colors are always non-negative).
Use Byte.
E
Hi Eric,Morning C,
One method is:
Dim addr as Byte
addr =
E
Hi again,
The first question was regarding:
uint8 addr =
I'm now at a line:
int addr =
What's the difference?
C.
Oshonsoft Basic uses Byte to send or receive SPI data.Hi I n N,
Ok, so if I set them both DIM AS WORDs in case one is 16 bits, I presume that will be ok?
Here is a section of DATA sheet, showing the area involved. Quite a puzzle!
C.
Where did you find that 16bit integer was used for data?
