There are other devices available like the **broken link removed** @ 2A or the **broken link removed** @ 7.5A or you can fit a bypass transistor to increase the current like **broken link removed**.
An LM338 adjustable regulator will handle 5A. But a critical factor is your power dissipation at high currents in a small package...(Vin-Vout)/Iout. https://www.ti.com/lit/ds/symlink/lm338.pdf
There are lots of other things you need to be aware of when building a power supply that will deliver more than 1 amp.
One-amp is easy to provide. But when the current exceeds this, a lot of new problems arise.
Keep the input voltage about 4v above the output voltage so the wattage dissipated by the 3-terminal regulator is at a minimum.
Provide filtering of at least 1,000u per amp on the input.
Try to separate the load into smaller current-requirements. One-amp loads are ideal.
Provide more than adequate heat-sinking.
Rectifier diodes must also match the current-requirement.
Don’t forget the wattage-dissipations of the regulators.
What kind of current are you looking for? The LM123 can source 3 amps, the LT1003 can source 5 amps. A couple to look into, if that's the range you'd like. There are a lot of regulators out there for various voltages and currents. Google will help you find part numbers, if you need different ones than the ones I just suggested.
