What is the best switch for 50Hz - 310V - 8A?
arvinfx
I am building an modified sine wave inverter . and I need to know about AC switches. We must use half-bridge switch to make provide ac modified sine wave, but I don`t know what kind of switch is good for it?
Mosfet - Transistor - IGBT?
For me I would go with IGBT's being they are robustly built, easy to control with a dedicated driver IC and little else, plus they generaly have high voltage ratings and good current handling abilities in a small package and are rather cheap to buy.
For basic ratings I would suggest using something with a 2x volt rating over your peak rail voltages and at least 4x your estimated peak amps you plan on switching so any that are rated at 600 V or higher and 30+ amps should be good enough.
As far as frequency goes 50 Hz is pretty low far as IGBT's are concerned so that wont be a problem with any model you chose.
