Again What is the life-estimation of CMOS ICs 4093 & 4060... ..
If this ic works 24hr from 12v dc power supply !
Ok... How many days can this electrolytic capacitors can work with this IC ......if you use electrolytic capacitors in the circuit,
If you operate them at room temperature they will last a very long time.Ok... How many days can this electrolytic capacitors can work with this IC ......
I used to work for a large electronics manufacturer, we used over 1000 4000 series CMOS IC's every day. We used such large quantities that we received credit for defective IC's we returned to the manufacturer. Bad IC"s were sorted by type and manufacturer so they could be returned for credit.which brand is best for cmos 4093 & cmos 4060...
Modern transistorized integrated circuit logic gates have MTBFs greater than 82 billion hours (8.2×1010) hours,[5] and need them because they have so many logic gates.
Thats a good one thanks scrooge.A company made a surge arrestor with a window that showed the little MOV. It was labelled, "If it turns black then send it back".
They all turned black.
