What is this part on my solar controller
Zosima_
Greeting!
Not sure if this the correct forum but I need help identifying a part on my solar charge controller circuit board. It got fried out from a loose ground. I have found similar however it doesn’t have 4 pins just 2.
Zosima
If you mean the green burned connector?
Carefully measure the spacing between the pins - there are several different sizes / pin pitches.
Then have a look through these to find an appropriate one.
You can search that part number on different sites afterwards, if you can't use Mouser.
Zosima!
My friend is working on it and he will guide you. Find your solution by visiting this website
Deleted by moderator
If there is still no solution then you can tell me your example again on this website Deleted by moderator
Spammy links removed - Moderator
As everyone has said - it's a simple terminal block - main problem is getting one the exact same size, there are a bewildering variety of sizes.
I've got a small selection of differtent sizes at work - mainly from when I've ordered the wrong size! :D
