What is this Harbor Freight flash light bulb called?
What is volt & amp rating?
Is this an LED type light bulb?
From the info you have supplied, probably "Unobtainium".What is this Harbor Freight flash light bulb called?
Did you intent to post a picture of it?
I was wondering how long it would take to get back to a flasher circuit![]()
After testing the brightness of 7 LED light to 1 of those square LEDs the square LED seems to produce several times more light.
Re. LED replacement torch bulbs; I got one for my 5 D-cell maglite, when the LED replacement to fit that first came out.
It's still got the same Duracell batteries in it that I used when I fitted the new "bulb" - they expired 1999 so that must be somewhere from 25 - 30 years ago!
(And it still works perfectly, blindingly bright. A sad reflection on the quality of newer cells really, as I've had several far newer sets of duracells start leaking in things long before they were out of date).
