hi everybody ..
I hope I find my needs in this great board ..
Now I am trying to initialize MMC SanDisk 1GB using my own code (without using mikroC library) with PIC16F877A ..
When the card is initialized, I want my GLCD to display the word "Ready", otherwise I want to display "Initializing ..." ..
before anything, I want to display "WELCOME" ..
the GLCD is functioning properly alone, but with my code, the glcd displays nothing ..
here is my code:
//module connection
char GLCD_DataPort at PORTD;
sbit GLCD_CS1 at RB0_bit;
sbit GLCD_CS2 at RB1_bit;
sbit GLCD_RS at RB2_bit;
sbit GLCD_RW at RB3_bit;
sbit GLCD_EN at RB4_bit;
sbit GLCD_RST at RB5_bit;
sbit GLCD_CS1_Direction at TRISB0_bit;
sbit GLCD_CS2_Direction at TRISB1_bit;
sbit GLCD_RS_Direction at TRISB2_bit;
sbit GLCD_RW_Direction at TRISB3_bit;
sbit GLCD_EN_Direction at TRISB4_bit;
sbit GLCD_RST_Direction at TRISB5_bit;
// Software SPI module connections
sbit SoftSpi_SDI at RC4_bit;
sbit SoftSpi_SDO at RC5_bit;
sbit SoftSpi_CLK at RC3_bit;
sbit SoftSpi_SDI_Direction at TRISC4_bit;
sbit SoftSpi_SDO_Direction at TRISC5_bit;
sbit SoftSpi_CLK_Direction at TRISC3_bit;
// End Software SPI module connections
void sendCommand(int cmdIndex); //function prototype
void main() {
unsigned char Response;
Soft_SPI_Init(); // Init Soft_SPI
Glcd_Init(); //Init. GLCD
// Glcd_Set_Font(font5x7 , 5, 7, 32);// Change font
Glcd_Fill(0x00); //Clear GLCD
Glcd_Write_Text("WELCOME",0,0,1);
TRISC.B1=0; //Make RC2 output pin (CS or SS Pin)
PORTC.B1=0; //Hold CC=0
delay_ms(4); //Delay about 75 clock pulses at 20KHz
sendCommand(0x00); //CMD0 for S/W reset
Init:sendCommand(0x37); //CMD55 to tell that the next command is Application Specific
sendCommand(0x29); //ACMD41 to Initialize the SD Card
Response= Soft_Spi_Read(0x00);
if (Response==0x00)
Glcd_Write_Text("Ready !!",20,4,1);
else
Glcd_Fill(0x00);
Glcd_Write_Text("Initializing ...",20,4,1);
goto Init;
Soft_Spi_Write(0x40+cmdIndex); //Send command of index cmdIndex
Soft_Spi_Write(0x00); //Send 4
Soft_Spi_Write(0x00); //Clear Bytes
Soft_Spi_Write(0x00); //As
Soft_Spi_Write(0x00); //Argument
Soft_Spi_Write(0x95); //CRC = 0x95 for CMD0 and not important for SPI mode
also I am asking about the red number, this function is to read data from spi bus, why do we need to assign data to send ..?
Great thanks to everybody ..
here is my code:
//module connection
void main() {
if (Response==0x00)
else
Glcd_Fill(0x00);
goto Init;
