What is Zener diode max current?
anso-engineer
Hello, in the datasheet of 1N4728A indicated that max current is something like:
But where Pv goes from? I saw somewhere that this is Ptot with some towards to the reducing value, but it's not pretty understanable for me.
Pv is the wattage - 1.3W in this case.
It's just basic electronics formula - you know the wattage, you know the voltage, so it's trivial to calculate the current.
Watts = volts x amps
Reconfigure: amps = watts divided by amps.
They can't give a specific figure, as it varies depending on the actual zener voltage.
When the Zener diode's specification is given as P/V (power per voltage), it refers to the Zener diode’s power-to-voltage relationship under specific conditions, typically in terms of how much power is dissipated for each volt of Zener voltage. This is often used to express maximum power dissipation per volt of voltage regulation.
Here's why it might be given this way:
1. Power Dissipation and Voltage Rating Relationship
  • P/V is essentially the power dissipation per unit of Zener voltage. By specifying this, manufacturers help engineers understand how the diode behaves across different voltages.
    For example, if you know the Zener voltage (Vz) and the maximum power dissipation (P_max), you can figure out how much current the diode will be handling and whether that falls within safe operating conditions.
2. Efficiency of Power Handling
  • P/V gives you a way to estimate how much current the Zener diode will need to handle for a specific voltage to achieve a certain level of power dissipation.
  • It’s a simplified specification that allows engineers to calculate and scale the Zener diode’s capacity for larger or smaller voltages. It essentially tells you how much power the Zener will dissipate relative to the voltage it's regulating.
3. Scaling Power for Different Voltages
  • When a Zener diode is used in different voltage-regulation applications, you can use the P/V value to scale the power dissipation for a range of operating voltages.
    For example, if the specification says "P/V = 20mW/V," this means for every volt of Zener voltage, the diode will dissipate 20 milliwatts of power. So:
    • If the Zener voltage is 5V, the diode will dissipate 5V × 20mW/V = 100mW.
    • If the Zener voltage is 12V, it will dissipate 12V × 20mW/V = 240mW.
4. Simplifying Design Decisions
  • By giving the P/V value, manufacturers allow engineers to easily estimate how the diode will behave across different operating conditions without needing to calculate the current manually for every situation. It's a shorthand method for understanding the diode's power dissipation relative to the voltage it regulates.
Example:​
If the datasheet of a Zener diode specifies P/V = 10mW/V, this means for each volt of Zener voltage, 10mW of power will be dissipated.
  • So, for a 5V Zener voltage, the diode would dissipate:5V×10mW/V=50mW5V \times 10mW/V = 50mW5V×10mW/V=50mW
  • Similarly, for a 12V Zener voltage, it would dissipate:12V×10mW/V=120mW12V \times 10mW/V = 120mW12V×10mW/V=120mW
It’s a quick way to understand the power-handling capability of a Zener diode in relation to its Zener voltage.
Conclusion:​
The P/V specification is a shorthand way of communicating how much power the diode dissipates for each volt of Zener voltage. It allows you to scale the power dissipation for various voltages, making it easier to design and assess how the diode will behave under different operating conditions.
Simple math for the 1N4728A would give 1.3/3.3 = 393mA as absolute maximum. Data sheet shows a test current of 76mA, and Maximum regulator current of 276mA.
So, the "safe" area (rule of thumb) of zener regulation would be between those two numbers, provided the zener is at ambient temperature. The closer it is to the test current, the less heat it will dissipate. It may regulate below the test current as well, but you would have to experiment with that.
Unfortunately that datasheet does not give an actual P/V value (specification)
Be aware though, that the data sheet’s rated power is valid for an ambient temperature of 25C.
If the diode is enclosed and/or close to a heat generating device, like a regulator, the ambient that the diode sees may be higher.
You have to derate accordingly.
Also, most 1N4728 are rated 1W, not 1.3W. Some datasheets show the 1.3W rating only if the leads are very short (1/8") to a "heatsink" (copper trace/pad large enough to sink heat from the zener)
