What rule prevents us from taking the most largest group when there are don't care combinations in K-Map?
oslon
This is the K-map problem:
This is my solution.
But it's wrong as teacher says you can't pick that quad when you're with don't cares. Why? I don't know. Should not I pick the largest group? What's the edge conditions for this? Any ideas?
Logically I think you're right, but if you're trying to minimize the terms then you can discard the don't cares.
Here's the logic of the first one:
if (A=0 and B=0) or (A=1 and B=1) then
    out = 1
else
    out = 0
Here's the logic of your solution (replacing the 'dont cares' with a 1):
if (A=0 and B=0) or (C=1) or (A=1 and B=1) then
    out = 1
else
    out = 0
In your solution you end up with a 'C=1' term, which you really don't need
