Hey all.
I am hoping you guys might be able to help me figure this problem I am having out. I learned to program a pic16F84a back in school, but that was 8 years ago. Sadly it is true that if you don't use it, you lose it.
Most of it is slowly coming back and I have found some good tutorials out there, but I am having trouble with the burning process.
I have MPLAB IDE v8.56 on my machine but can't seem to get it to export a .hex file that I can burn into my chip. I have one of those lil Do it yourself kits. Kit 81 v4.
It comes with a lil burning program.
It seems to work fine because I was able to load the sample hex files that came with it and get the pic to preform properly. But when ever I make changes to the .asm, (nothing major, just added an extra delay to the flashing steps) and try and export the chips does nothing.
I have attached the sample hex and asm file that came with the burner (binarylr) and then the hex code for the modified one i tried ( binarylr2xB)
Am I doing something wrong in MPLAB? Is there an easier way to convert a asm to hex?
THanks so much in advance for your help. I think once I can figure out the workflow for this part, I can start testing the program I have designed.
