I have connected 50Ohm 50Watt resistance and 50Ohm 25Watt Variable Resistance in parallel.I gave an input of 26V DC and I should get an output of Max 4A Current as i gave 40watt bulb as load.Do I require any more resistance?
My bad, poorly phrased on my part. Two individual threads one each in two sections. Still, there are two active threads with the same somewhat vague question. I also do not quite get the AH reference. Maybe looking to discharge a battery?
Some clarification please: Is a 4 AH load supposed to be a load that will draw 4 Amps from a battery for one hour before the battery dies? That's what I would expect it to be.
V=IR, so 24=(4)(R); R has to be 24/4 or 6 ohms. P=VI so a 40 W=24/I = 1.66 amps >>> R = 24/1.66 =14.45 ohms
1/Rt=1/R1+1/R2
1/6=1/14.55+1/R2
Solve for R2, will tell you the additional resistance you need. By inspection, it also tells you that R2 has to be less than 14.55.
Cavat: The 40W bulb better be rated for 40W at 24V.
