I have a bunch of these kinds of ignitors https://www.sparkfun.com/products/retired/11218
not literally those, but probably made with the same parts, same manufacturer, and so fourth.
today i realized 4 i bought were dead. they work but only produce some 1kv or so, the input however is about the same.
It happens allot, a huge flaw in these things is that the input wires usually have resin on them which, either chemically, mechanically, or both, brittles them making them fall off right at the base, so difficult to resolder on. Also, they overheat and fry quite quickly due to the incredibly poor heat conductivity.
What i want to do, is get the circuit out of that resin, so i can replace the transistor, or just extract the transformer at least which is all i need to build my own setup for one that runs constantly, for producing ozone which these things are apparently capable of doing.
Also i want to see what it all looks like in there too. i understand of course that without an insulator it would be impossible to use these transformers in open air.
So, what do i do to get the resin away?
Understand im not doing this explicitly for making ozone, or anything i should be advised to just "go and buy it", if thats your recomendation, or anything other than an honest answer or advice for extracting the circuitry, then lets pretend that this is a scenario in which it is impossible. I spent allot of time playing with these and reselling them too, im genuinely curious about the inner workings.
One more thing to clarify, this resin is most likely there to stop the transformer inside shorting on itself or damaging the other components, its high voltage insulative resin, if anyone knows what its composed of and how to get rid of it.
At very least i want to be able to extract the transformer and look at the oscillator, though i think its likely just a simple flyback setup modulated like disposeable cameras are, with a center coil for measuring flux or something i cant remember.
