Can you plug it into a different outlet? is anything else on your house running? Try turning off ceiling fans and TV's.
I can feel a 'tingle' on my laptop sometimes, when ac adapter is plugged in, and I can measure up to 70 volts betwen the case and an earthed pipe.
This is a common problem with a lot of laptop mains adaptors.
They quite often use capacitors between the live/neutral feeds and ground or create a virtual ground on 2 pin adaptors. I think they do this to reduce EMI.
