Which FET to use with an LED driver
James77
Hi All,
Please would someone advise me as to which device would best suit the below application.
I am programming a PIC to drive a Texas Instruments TCL5947 (PWM 12-Bit 24 channel LED driver) via SPI.
I would like to hook up High-Bright LED's (5w) to each channel. The issue I face is that the TLC5947 drives the output low (0v - sink)
Am I able to use a PNP FET to switch my HB-LED's on from the TLC's sink outputs? Out of curiosity, if the TLC drives the outputs low (sink) what does it do when off? Are the outputs high or do they float?
you can use a p channel mosfet to drive yr leds(or a pnp transistor ...)post the schematic so we can see whats going on...the op will probably go hi it wouldnt b allowed to float because that would give uneliable operation
