kinarfi
In the attached drawing, I used 5k resistors in the Wheatstone Bridge, If I change the resistors from 5 to 10k or even a 100K or higher, will it effect the stability of the circuit. The power is supplied by car battery, so supply loading shouldn't be a problem. As I said on the attachment, My guess is NO.
But it will make the 50 ohm pot more precise.
Is having a higher current flow more or less stable than a lower current flow for the same voltage, or is it the same?
Kinarfi
Kinarfi
