A controller has 100mA Sinking Driver. I connected one terminal of 500 Ohm resistor to the output of this driver and other terminal of resistor is connected to +12V DC power supply. When output of this driver is Logic Low, current flows from power supply, through 500 Ohm resistor, into the driver. I measured this current to be 21mA.
How does this circuit work? Does 100mA spec. mean that this driver can sink 100mA max.? What resistor value do I need to tie to +12V DC power supply to sink more than 21mA? What's the resistance at the output of the driver? Does this resistance change for different resistors connected to DC power supply?
Thanks.
Thanks.
