I'm struggling to keep my mind wrapped around the function of the transformer and, in the process, regretting the days I snooze back in my Electromagnetics class as an EE student when I was a boy
I'm searching for an abstract explanation, but not just an equivalent one. I want it to be rooted in the real mechanics of what's going on. I've found a few excellent sources on the web, but all of them seem to skirt this issue.
I've come across a few interesting clues, so I'm pretty nearly now, I guess, but still yearning![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Fact 1: While it varies sinusoidally, the "peak-to-peak" flow in the center of the transformer, so to speak, is basically constant (for a given voltage applied to the primary) regardless of the load.
My initial intuition was that the difference in the "power" of the flux was what moved the energy from the primary to the secondary, but this would seem to contradict the idea. I assumed the primary would produce a lot of fluxes dependent on the current running through it, and the secondary would suck it up and create the current on its own. No chance, it feels like that.
Then, of course, there is the fact that the Flow Formula only includes voltage, time (frequency) and turns![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Fact 2: The current in the main is (usually) 90 degrees out of phase with no load voltage and is roughly centered in phase at full load.
It seems really interesting and yet strangely rewarding. This will mean that the Volt-Amps (VA) of the primary remain stable and that the power factor varies as the actual load on the secondary decreases.
Yet I really don't know how the energy is being transmitted. It seems slightly like the flux is only there as an energy conductor or something, and the other phenomenon is a bit of energy transfer.
Will anybody see what I'm missing and explain what's going on?
