-RF radiates on antenna but why AF (audio friq) not?
-How and why RF can radiates surprisingly in single rod in whip and in different separated rod in dipole? Why RF is such special?!
I don't think your premise is correct. You can pick up 60 Hz hum from power lines. Here another link you may find interesting: http://www.vlf.it/trond2/below10.html
Extremely low frequencies have very long wavelengths. That is/was used to advantage in the LORAN C systems. The transmitting antennas were quite long.
This is not a simple question to answer on a forum.
The amount of energy radiated is down to frequency. e=hF, energy = Boltzmann's constant x frequency.
As frequency is directly related to wavelength, the effiency of a radiator is down to its length as a radiator c/w its wavelength.
VLF transmitters such as Loran and time signals such as DCF77 and MSF60 require huge lengths of aerials to radiate in any terms of efficient. Due to propogation properties (a degree in itself) they can travel hundreds of miles. They tend to be known in the UK as aerial farms where vast wire lengths are run over many Km in total.
GSM at 900MHz/1800MHz in the UK is a much shorter wavelength and can radiate quite efficiently in an aerial a few cm long but cannot propagate more than a few tens of miles due to many reasons including atmospheric absorbtion, earth curvature.
50Hz/60Hz radiation tends to be magnetic coupling as the radiating elements of the wires is far too short to be efficient.
