simrantogether
Is the cold air in winter usually Dry... or some moisture content is there...
Regards,
Simran..
Regards,
Simran..
Torben said:Where I grew up (northern BC) for the same time period, the temp. was around -15 to -20 deg C, and the relative humidity was around 50%.
Torben
Pommie said:The 50% you quote is relative humidity. Air at 20°C and 50% RH will contain 16 times more water vapour than air at -20°C and 50% RH.
Relative Humidity is the amount of water that the air contains compared to the maximum amount it can hold at that temperature (and pressure).
simrantogether said:Can this cold dry air evaporate the water easily ...
or the air that is hot but moisturious evaporates water easily...
The snow that's been working its way across the continent finally hit New Brunswick last night. Woo hoo! Snow day for teachers! But with the temperature right around 0 Celsius, it was wet, heavy stuff even when I started digging out the cars at 7am. I wonder if the sea salt (near the coast) plays a factor in wetness relative to temperature?If there is any doubt about how much water can be contained in cold air from Canada, just come here and help shovel for one of our 12+ inch snowfalls.
Hank Fletcher said:I've known Africans who've moved to Canada and broken down crying their first winter - they just can't take the cold and snow! That said, I don't reckon I'd survive 5 minutes in the 40 Celsius weather my Indian friends find "just about right."
