BroncoDave
You mean can anyone NOT guess what happened
Go on, take a guess.
My guess is they didn't last long.
You lost Mains....so you have not tested them yet....
Sneaky question = sneaky answer.
Regards,
tvtech
Good for youWrong. It works perfectly. It just doesn't put out as much as it says on the front of the charger. It says 2/35/200 and does 2/25/150. The only parts inside are the transformer, 2 mode switches, the diodes and an amp meter.
Now what??
Answer: Test it to see all is good on the job
Don't blow anything up. Yet.
Before you start in earnest, have you done a ground-level test of the whole caboodle (batteries + wire + magnet) to see how hot the magnet gets in use? That might be a limiting factor.
Yep, The numbers add up now - at least pretty close. It would seem your coil has a resistance of .2 ohms and the wire .4 ohms. So you are loosing all the juice in the wire instead of the magnet.
Tell me again about the permanent magnet?
Some general information on electromagnets:
As already mentioned, the magnetic strength is a function of the current in the winding, and the number of turns in the winding. The term is amp-turns. If you double the number of turns, you will have more magnetic strength with the same current. Of course, the DC current through the winding is a function of the applied voltage and the resistance, as per Ohms law.
The magnetic field, or lines of force, flow between the two open ends of the winding, beginning at the axial face of the winding. If it is an E core, then the magnetic field splits, with half of the force flowing from the center face to each of the two outside faces.
Note that I said that the magnetic field begins where the winding ends. That means that, if your winding only goes partway up the core, that some of the magnetic field goes right across the unwound length instead of going out from the ends of the core. In other words, if the winding doesn't cover the full length of the core legs, a lot of the magnetic field isn't out where it does you much good. That being said, if you are using prewound bobbins that are shorter than the length of the core legs, it is better to position the coils close to the open ends, than at the the base. That will maximize the force lines from the open end to be out in your 'working' area.
More info on the working of electomagnets can be found here: https://en.wikipedia.org/wiki/Electromagnet
The voltage multipliers in that thread only work with AC input.
I have 110 and 220 a/c power right at the well. If the multiplier puts out dc that's what I need. Then I wouldn't need batteries or a battery charger. All I need to do is build the multiplier to put out the amount of power that will do what I need to power my magnet or build a magnet that can handle the power I need to get this job done. Ijust need to figure out what to build and build it. That's where you geniuses come in. The building part I can handle. I can fabricate just about anything. I just need to know what parts to get and what order to put them together in. You guys have gotten me this far. Can you get to the finish line?
There are several issues here,
First is that when dealing with mains voltage things get far more dangerous than a large battery-powered electromagnet. High current also means lots of heating, which presents a burn or fire hazard. Furthermore, building a multiplier that can stand that kind of voltage and current may become difficult and expensive. Also keep in mind that when you increase the voltage in a multiplier circuit, the current does not increase. You can't get out more power than you put in, so your current would decrease significantly. Also, even if you could get high enough amps, you would likely trip the breaker serving your outlet.
There are all sorts of other variables that do not appear to have been taken into consideration. I would keep experimenting with your battery-powered one if I were you.
Matt
