Wireless communication display on LCD
mikael
I've no clue what im doing wrong while trying to get this work everything is correctly connected, RX output is sending signal and the TX port is receiving checked it with oscilloscope.
Im using TX433 and RX433 modules, c18 code. Am I doing something wrong when receiving data? Cuz thats the only thing that can cross my mind at this moment.
When i check RX&TX ports on oscilloscope they are having the same structure except that TX port has a ppv 400mV and RX ppv 2V or something around there. Can that be a problem for the circuit.
Sender
#include <p18f2550.h>
#define test 0x30
#define test 0x31
void send_data(char data);
void UART(void);
void delay_ms(int sec);
void UART(void)
		TXSTA = 0x20;						// low baud-rate & 8bit
		SPBRG = 155;						// 1200 baud rate & XTAL = 12MHz
		SPBRGH = 0;
		TRISCbits.TRISC6 = 0;
		TXSTAbits.TXEN = 1;					// TX port!
		RCSTAbits.SPEN = 1;					// enable entire serial port of PIC18
		RCSTAbits.CREN = 1;
		TXREG=0x00;							//  Dummy send
		// BAUDCON = 0x10
		while(PIR1bits.TXIF==0); 			// wait until all sent
		TXREG = data;						// send data
void delay_ms(int sec)						// 50ms delay
	int i;
	for(i=0;i<sec;i++)
	T0CON=0b00000000;
	TMR0L=0x85;
	TMR0H=0xEE;
	T0CONbits.TMR0ON=1;
	while(INTCONbits.TMR0IF==0);
		T0CONbits.TMR0ON=0;
		INTCONbits.TMR0IF=0;
void main(void)
	UART();
	while(1)
		send_data(test);
		delay_ms(6000);
		send_data(test2);
Receiver
#include <p18f4550.h>
#include "lcdlib.h"					// #include USART is an option
void main_init(void);
void RC_ISR(void);
void chk_isr(void);
#pragma code My_HiPrio_Int=0x08  	// high prio
void My_HiPrio_Int(void)
	_asm
		GOTO chk_isr
	_endasm
#pragma code
#pragma interrupt chk_isr
void chk_isr(void)
	if(PIR1bits.RCIF == 1)			// recive interrupt
		RC_ISR();
	TXSTA = 0x20;
	RCSTA = 0x90;					// enable serial & receiver, check notes
	SPBRG = 255; 	 				// 9600 baud rate / XTAL = 20MHz
	SPBRGH = 0;						// can be skipped?
	TRISCbits.TRISC7 = 1;			// rx input
	TXSTAbits.TXEN = 1;
	RCSTAbits.CREN = 1;
	RCSTAbits.SPEN = 1;
	PIE1bits.TXIE = 1;
	PIE1bits.RCIE = 1;				// recive interrupt
	INTCONbits.PEIE = 1;			//peripheral intrrupt
	INTCONbits.GIE = 1;				// all interrupts
	// BAUDCON 0x20
void RC_ISR(void)
	char indata;								// DATASHEET *
	indata = RCREG;								// 9. Read the 8-bit received data
	commd(LINE_1);								// RCREG register.
	prnts(indata);
void delay_ms(int sec)							// delay 50ms * x
	int i;
	for(i=0;i<sec;i++)
	T0CON=0b00000000;
	TMR0L=0x85;
	TMR0H=0xEE;
	T0CONbits.TMR0ON=1;
		T0CONbits.TMR0ON=0;
void main(void)
	char klar[] = "klar";
	lcd_init();
	main_init();
	commd(LINE_2);
	prnts(klar);
	while(1){
	delay_ms(1500);
Any help or idees are appreciated!
Basically you can't send plain RS232 over a wireless link, you need Manchester coding (or similar) - have a read of my tutorial for the reason..
Adding hardware inverters at each end 'may' make it useable though.
yeah that it is very true. But I thought of make it simple and just send number to lcd and display it. But I'll give it a shot and make later a decode system.
