Hello members and most knowledgeable ones ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
My project involves a 240v hoist that is being used to lift goods from one floor to the next. 2 floors only.
I purchased a control system from carymart to get rid of the pendant controller and use a wireless transmitter to control it.
The receiver unit also has connections to enable limit switches and manual switch controls to be used.
On each floor will be a "call button", so to speak which will be connected to the manual switch controls. Planning on using an illuminated momentary push button switch.
Now I pulled a 12v relay out of my car to test how to connect it with help from you tube and got it all working using a 12v battery as the supply. Circuit energises and LED light comes on when momentary button is depressed and all switched off once limit switch triggered.
Yippee I thought as the terminals on the carymart receiver show 12v dc. However when I connected my makeshift test setup to the receiver it wouldn't control the relay and you had to keep the momentary button depressed for it to work.
Reading show that the output voltage from the receiver drops to 3V once the start button is pressed (from 12V). My best guess is that this is not enough voltage to control the 12V relay, hence not working (and very dull LED).
So once more, many hours of googling looking at 3V low level signal relays and they are minuscule. Is there a simple way of getting 12V at the relay from a 3V source? For ease I would like to use a 12V relay so my fat fingers can work with it and hopefully just use a socket mount.
I can get around all this by just using a push button switch that needs to be kept depressed until the hoist platform reaches the limit switch but this just seems too easy. Why not use relays and an illuminated switch and set it up as a single push switch for each level. Except this is starting to do my head in and now is my time to ask for help!
My first post here, not sure on the rules of web links yet but can link to receiver and attach a pic of my circuit in needed.
Hopefully all this makes sense and my terminology is understandable
Thanks in advance!
Thanks in advance!
